![]() | Important |
Deleting a palette will remove all references to the palette that have been recorded in cues, scenes and other palettes, and replace the references with numerical parameter values. Creating a new palette in the same location will not replace the references, which are removed once the palette is deleted. |
To delete a palette using the command line:
Colour
1
Delete : deletes Colour Palette 1.
Click OK to confirm the delete.
Or, from the palette directory:
Press and hold Delete whilst selecting the palette to be deleted from directory.
Release the Delete key. A dialog will appear asking you to confirm the delete.
Click OK.
![]() | Tip |
If you prefer not to be asked to confirm the delete action, select Don't Ask Me Again in the confirmation window. You can re-enable the confirmation by going to Setup → Preferences → Programming and selecting Confirm before deleting directory items. |
