35.13 Master Wing 4
Prev
Section 35: Technical Specifications
Next
35.13 Master Wing 4
35.13.1 Input and Output Connections
Mains in:
Built-in Power Supply with IEC 320 connector 100-240V, 50/60Hz, 1.5A maximum
Digital video in:
DVI-D connector
USB:
Type B USB input socket USB-A 2.0 High Speed (x2)
35.13.2 Power, Weight and Dimensions
Power:
75W
Weight:
27.2 lbs (12.33 kg)
Dimensions:
20.14” (511.56mm) wide
24.02” (610.05mm) deep
9.62” (244.34mm) high
35.13.3 Performance
Display:
15.6" Diagonal active matrix TFT LCD
Native resolution:
1366 x 768
Input frequency:
31.5 - 80 kHz (H), 56-75 Hz (V)
Contrast ratio:
500:1 (typical)
Viewing angle:
160 x 160 degrees (typical)
Response:
80 ms (typical)
Brightness:
300 cd/m2 (typical)
