35.12 Playback Wing 4
35.12.1 Input and Output Connections
Mains in: Built-in Power Supply with IEC 320 connector
100-240V, 50/60Hz, 1.5A maximum
Digital video in: DVI-D connector
USB: Type B USB input socket USB-A 2.0 High Speed (x2)
35.12.2 Power, Weight and Dimensions
Power: 75W
Weight: 27.6 lbs (12.51 kg)
Dimensions: 20.14” (511.56mm) wide
24.02” (610.05mm) deep
9.62” (244.34mm) high
35.12.3 Performance
Display: 15.6" Diagonal active matrix TFT LCD
Native resolution: 1366 x 768
Input frequency: 31.5 - 80 kHz (H), 56-75 Hz (V)
Contrast ratio: 500:1 (typical)
Viewing angle: 160 x 160 degrees (typical)
Response: 80 ms (typical)
Brightness: 300 cd/m2 (typical)
