You can copy or move cuelists, scenes and group masters to a page, or remove them, as well as clearing the whole page. If you change which cuelists, scenes or group masters are assigned to the current page, then that assignment will automatically be recorded as part of the page. Changes made to cuelists, scenes and group masters (such as editing their contents) remain with that item, and not with the page.
Copying a cuelist to a page creates a new cuelist which is independent of the one it is a copy of. Any changes made to this new cuelist will not effect the original cuelist. To copy an existing cuelist to a page:
List
2
Copy
Choose : copies cuelist 2 to the selected
master.
You can also copy a cuelist from one master to another:
Choose : press the Choose key of the master with the cuelist you want to copy.
Copy
Choose : press the Choose key of the master you want to copy the cuelist to.
You can copy scenes and group masters in the same way.
Moving a cuelist to a page does not create a new cuelist, so changes made to the cuelist will affect all other uses of that cuelist on other pages. To move an existing cuelist to a page:
List
2
Move
Choose : moves cuelist 2 to the selected
master.
You can also move a cuelist from one master to another:
Choose + Move : press the Choose key of the master with the cuelist you want to move.
Choose : press the Choose key of the master you want to move the cuelist to.
You can move scenes and group masters in the same way.
To remove a cuelist, scene or group master from a page:
Delete + Choose
Note that this will only remove the item from the master; the item will not itself be deleted from the show.
To clear all cuelists, scenes and group masters from the current page:
Open + Page : opens the Page Directory window.
Press Clear Current Page in the Page Directory.
Note that clearing the current page will remove items from the masters; the items themselves will not be deleted from the show.
![]() | Important |
When you clear the current page, any cuelists, scenes and group masters that were previously loaded onto the physical masters will be released, and their contents will no longer be output from the console. |
