You can record scenes either directly to a physical master for immediate playback, or to the Scene Directory.
To record a scene:
Create the look for the scene in the Programmer or editor.
Record, Scene : the Scene Directory window opens.
Select the destination location in the Scene Directory window.
Alternatively, enter a number on the keypad and press Enter.
You can record a scene directly to a physical master. Hog 4 OS will automatically put it in the next available location in the Scene Directory:
Record, Scene
Press the Choose key above the desired physical master.
You can give a scene a name that will be displayed in the Scene Directory window:
Open + Scene : open the Scene Directory.
Check that the Guard button is selected, so that you don't accidentally activate a scene when pressing its button in the directory.
Select the scene.
Set
[name]
Enter : type in the name.
![]() | Tip |
To name a scene immediately after recording it, pressing the Set key will open a Quickname window. Enter the scene name and select OK. |
