29.3 Create a USB Flash Drive for full install of Hog 4 OS v3.9.0 and higher
The following procedure demonstrates how to create a Full Install USB flash drive for use with all Hog 4 OS Consoles.
This procedure is NOT compatible for full installs of Hog 4 OS v3.8.0 and lower. For full installs of Hog 4 OS v3.8.0 and older please refer to Create a USB Flash Drive for full install of Hog 4 OS v3.8.0 and lower.
  1. Download and install the Etcher application to your Windows PC or Macintosh Computer. ( http://www.etcher.io/ )
  2. Insert a 2GB or larger USB flash drive into one of your computer's USB ports and make sure it is the only external USB drive connected to your computer.
  3. Launch the Etcher Application.
  4. Click the "select image" button in the Etcher application.
  5. Use the file browser pop-up to select the full restore file that you downloaded from the High End Systems website.
  6. Click the FLASH button in the Etcher application.
  7. When Etcher has finished flashing the USB flash drive a “Flash Complete” message will appear.
  8. Remove the USB flash drive from the computer. Don’t worry if the USB flash drive led is flashing.
  9. Proceed with step four of the full install procedure: Console Software Full Install.
