The following procedure demonstrates how to use a Windows Computer to create a Full Install USB flash drive for use with all Hog 4 OS Consoles.
This procedure is NOT compatible for full installs of Hog 4 OS v3.9.0 and higher. For full installs of Hog 4 OS v3.9.0 and higher please refer to Create a USB Flash Drive for full install of Hog 4 OS v3.9.0 and higher.
Download and install Linux Live's "USB Stick Maker" to your Windows PC. ( http://www.linuxliveusb.com/ )
Insert a 2GB or larger USB flash drive into one of your Windows computer's USB ports.
Launch the Linux Live USB Creator application.
In step 1 of Linux Live select the USB flash drive that you plugged into the computer.
In step 2 of Linux Live click on the ISO/IMG/ZIP button.
Use the browser that pops up to select the full restore file you downloaded from the HES website.
Skip step 3 of Linux Live.
In step 4 of Linux Live enable the following options:
Hide created files on key
Format the key in Fat32
Click on the lightning bolt in step 5 of Linux Live.
A notification will pop up warning you that your USB flash drive contents will be erased. Click okay.
When Linux Live is finished it will alert you.
Remove the USB flash drive from the computer.
Proceed with step four of the full install procedure: Console Software Full Install.
