28.5 Configuring the Console for Visualizer Connectivity
28.5.1 Enabling the Visualizer Stream on the Console
  1. Navigate to the start screen of Hog 4 OS and click on the Control Panel button.
  2. Select the Startup tab.
  3. Enable the "Run Visualizer Stream" button and click okay.
28.5.2 Configuring a Show for Visualizer Connectivity
  1. Load a new or existing show file on your console.
  2. Open the network window (setup, network).
  3. Click on the visualizer node listed in the network window.
  4. Click on the settings button located at the top of the network window. This will open the visualizer settings window.
  5. Enter the IP address of the visualizer PC into the "visualizer IP address" field.
    If a visualizer is already running on the network you can use the "detected visualizers" drop down menu to auto-populate the IP address and visualizer protocol and manufacturer fields.
    In you are using WYSIWYG, all steps listed in WYSIWYG Configuration must be completed in order for WYSIWYG to be listed as detected visualizer.
  6. Select the appropriate visualizer protocol and manufacturer using the drop down menus. Use of the CITP protocol for visuzalier streaming to Capture requires Capture Version 2019.0.13 or greater.
  7. Click okay to apply the changes. The Hog 4 console will now stream all of the universes directly to visualizer using the FixtureNet port on the back of the console.
