In addition to Art-Net, sACN, and DMX, Hog 4 OS consoles can control visualizers through a direct visualizer stream via the console's FixtureNet port. For most applications this requires installation of the Hog 4 Connectivity Driver on the visualization computer. Installation of the Hog Connectivity Driver is NOT required if running the Capture v2019 (or newer) application or a Capture v2019 (or newer) presentation file since CITP is supported for Hog visualizer streaming.
This section describes how to install the Hog 4 Connectivity application on your visualiser computer, how to physically connect the console to the visualizer PC, and how to configure both the visualizer PC and Console to enable direct Hog Visualizer Connectivity.
Visualizer applications that support direct Hog Visualizer streaming:
Capture: www.captures.se
Light Converse: www.lightconverse.com
Martin Show Designer: www.lighthouse.nl
Vectorworks Vision: www.vectorworks.net/vision
WYSIWYG/Cast: www.cast-soft.com
For visualizer product information, software licensing, and instructions on visualizer operation, please contact the visualizer manufacturer directly.
