Folders
Folders is provided as an alternative user customizable Browser. Folders, by default, is found in a tab located behind the Browser.
You may relocate the Folders tab by docking to another location in the application window pane, reference Application Window Panes.
Using Folders
A "Folder" is a container for user configurable Browser tree objects including; channels, stations, walls, processors, groups, control groups, Macros, overrides, triggers, timed events, presets, palettes, sequences and even spaces.
When the Folders pane is moved into a floating position or docked into a different location of the application display, you can easily drag objects from the Browser into a folder within the Folders pane.
Using Smart Folders
A "Smart Folder" is a dynamically updated folder of user customized Browser objects. The type of objects that may be included into a Smart Folder include channels, groups, macros, overrides, presets, processors, spaces, stations, timed events, and walls. Certain conditions of these objects can be applied as the filtered data of the object.
Smart Folder Builder
The Smart Folder Builder is a dialog that displays to create Smart Folders and Child Smart Folders. Begin creation of either by providing a unique name in the "Name:" field provided.
"Folder Conditions" are specific filter criteria that is applied to the selected object type(s) in the Smart Folder Builder. Selecting the [NOT] button for a folder condition provides additional filtering by exclusion.
Not all "Folder Conditions" are applicable to all Object Types. The table below identifies which conditions are applicable to each other.
  Channels Echo Channels Groups Macros Overrides Presets (6) Echo Presets Processors Spaces Echo Spaces Stations Timed Events Walls Echo Walls
name
space
project (5)
master               (2)
active       (3)
altered
inactive
running       (4)
affects
lockout threshold
user data (1)
Notes:
1) "user data" is a pseudo property that looks for the meta-data tag in the object, including custom user defined tags, as well as the default "User Data x" tags that are automatically generated by LightDesigner.
2) "master" is a raw value where 65536 is full and 0 is off.
3) a macro is active if it is running steps or, for toggle macros, has run the "On" steps but not completed the "Off" steps.
4) a macro will display as "running" when it is currently in its "On" or "Off" steps.
5) Presets will use their space's project's name to test against the filter.
6) Presets include palettes and sequences. Sequences will be expandable to show their steps.
Filtering Data in Folders
Browser objects can have User Data or User Data Tags which provide the Folders feature additional flexibility in filtering data. Filters can be based on an object type, more than one type (et.al. show only presets and groups that are marked with "xyz", show all presets that "affect" a specified space, or show all stations that are currently locked), or any other User Data or User Data Tag.
TIP: For example, to know at a glance what state each preset is in for a particular space, you would create a Smart Folder or a Child Smart Folder with presets selected as the object type and "affects" as the folder condition with the specific project or primary space selected.
The new Smart Folder will include all presets that affect the selected space. Each preset in the list also displays an icon which indicates its status. For example, when the preset is "On", the icon will display green, altered will display yellow, and when it is inactive, the icon displays with a gray background.
