Objects are any non-fixture element of your Augment3d model.
There are two ways to add an object to the Augment3d model.
Objects can be dragged from the Library and placed into the model.
Note: Objects are created with a (0,0,0) position on the XYZ axes when added to the model.
To add objects from within the Hierarchy, right-click, select Create, and choose the object you wish to add.
Objects can be copied and pasted by selecting the object in the Hierarchy and using CTRL + C to copy. Use CTRL + V to paste the object. You can also duplicate selected objects using CTRL + D. If working in macOS, use CMD instead of CTRL.
