Sometimes a cluster of fixtures, although separate and independent from one another, frequently need to be selected and programmed together while still maintaining the ability to be selected, programmed, and patched individually. Hog 4 OS solves this problem with a feature called fixture aggregation. To aggregate fixtures, simply assign dotted user numbers to the fixtures you wish to cluster together, ensuring that they share a common whole number and unique part numbers. For details on how to assign dotted user numbers to fixtures refer to Assigning Dotted User Numbers to Fixtures.
To select all fixtures in an aggregation: enter the common whole number shared among the fixtures on the command line and press enter.
To select an individual fixture in an aggregation: enter the whole number and part number of the fixture on the command line and press enter.
The fixture selection mechanisms described in Selecting Fixtures can also be used to further sub-select, range select, or laterally select specific fixtures in the aggregated fixture cluster.
![]() | Important |
Compound fixtures cannot be aggregated. |
