Plots can be created as entirely blank or pre-populated with fixtures.
To create a blank plot:
Ensure that no fixtures are currently selected.
Record
Pig + Fixture ("plot" should now appear on the command line after record)
Use the numeric keypad to enter the plot number you wish to create.
Enter
A new and entirely blank plot has now been created.
To create a plot pre-populated with fixtures:
Select the fixtures you want to have in your new plot.
Record
Enter
A new plot has now been created containing a box gang that contains all of the fixtures you selected in step 1.
NOTE: You can also use the plots directory to create a new plot by pressing on a blank directory button in the plots directory window after pressing record.
