17.11 Group Masters
Group Masters (sometimes referred to as inhibitive sub-masters) can be used to inhibit the intensity of a group of fixtures throughout the entire system. There are two types of group masters:
Physical Group Masters: created by assigning a group to a physical master.
Virtual Group Masters: groups in the group directory (not attached to a physical master on the current page). The intensity level of a Virtual Group Master is adjusted by holding down a group's cell in the group directory and dialing the fifth (or fourth) main encoder.
When a group master's level is inhibited it proportionally reduces the intensities of the fixtures within the group through the entire show (playback, editors, etc). For example, if fixtures 1<4 are in the programmer with intensities at 0%, 50%, 80% and 100%, then inhibiting a group that contains these fixtures will affect the intensity output as the fixtures as follows:
Fixture: 1 2 3 4
Group Master at 100% 0 50 80 100
Group Master at 50% 0 25 40 50
Master at 0% 0 0 0 0
Pressing the Flash key of an inhibitive master is the same as momentarily changing its fader level to 0%, taking all fixture intensities controlled by the inhibitive master to 0%. Intensity values are restored when you release the key.
Here are some important things to note about group masters:
To create a physical group master using the command line:
  1. Record a group containing the required fixtures. See Recording Groups.
  2. Group [group number] Move Choose
The Playback Bar will show the group name above the chosen master. When the master level is less than 100%, the Playback Bar will also display a bar showing the level. When the Flash key is pressed, the Playback Bar will display BO; see Figure 17.11, “The display of Group Masters on the Playback Bar”.
Figure 17.11. The display of Group Masters on the Playback Bar
Group masters on the playback bar at full, at 50%, and with the flash
						key pressed.
