Sheets
The Sheets tab is an editable spreadsheet view of all contents in a selected space including; channels, stations, connectors, Echo Expansion Bridges, spaces, walls, presets, palettes and sequences.
The Sheets tab is available in both the Design and Program/Simulate views, although the data displayed and editable in each view will vary. Only certain data can be edited from the Sheets tab, even with advanced user level settings.
To view the Sheets tab, first select the desired space from the Browser, or select a sub-space from within the Plan view, then switch to the Sheets tab. The data displayed in the Sheets tab directly represents the contents of the selected space (Primary, Sub-Space, Project, or Server Project).
