Most stations in LightDesigner are provided with default functionality and behaviors based on the typical system functionality. These control assignments and functions can be customized as required by assigning station control functions.
Station control functions can be assigned using a manual method of individually assigning a function to each control on a station or by using the Smart Assign Control Function and Smart Paste Control Function features.
Specific stations, such as the Occupancy and Light Sensors, require additional custom programming. Refer to Add ETC Paradigm Sensors for more information.
Each Paradigm Inspire Station (hardware) includes a three position page selection switch that enables a user to change the station function at the station. When"Assign default control/indicator functions to new stations" is set in your configuration's Preferences, all three pages are provided functional defaults in LightDesigner when the station is added into a configuration. You can manually configure each control and indicator for each page separately using Assign Station Control Function. The best method for assigning page control functions is while viewing the Inspire Station in simulation. See Simulate Station Controls
LightDesigner provides multiple methods, in addition to the Property Editor, to assign control functions:
Station controls can be simulated in the Program/Simulate view, using either the Plan workspace or Sheets tabs.
